Try using the standard reference-style markdown links as specified for instance in
They work in IA Writer, The Archive, Typora etc. and are part of the basic Markdown spec.
A clickable reference link, similar to a footnote, should appear and direct the user to the corresponding label in the document.
The link appears in preview mode between brackets (it’s not parsed at all).
- Operating system: macOS 10.14
