We strongly recommend you to search the forum with possible keywords before submitting a new bug report. Please also try your repro steps with third-party plugins and custom CSS disabled and see if it’s still reproducible. If it’s an issue with third-party plugins or themes, try contacting the author for help. Once you’ve done the above, delete this line.
I can’t reproduce the bug. It happens from time to time in source mode only in obsidian mobile on my Samsung Galaxy Tab S7+ and smartphone Oneplus 6
Well formatted document in source mode
Sghown in the attached picture
Operating system:
Debug info:
Operating system: android 12 (samsung SM-T970)
Obsidian version: 1.3.1 (65)
API version: v0.15.9
Catalyst license: supporter
Live preview: off
Legacy editor: off
Base theme: light
Community theme: Blue Topaz
Snippets enabled: 6
Plugins installed: 12
Plugins enabled: 12
1: Calendar v1.5.10
2: Advanced Tables v0.17.3
3: Editor Syntax Highlight v0.1.3
4: Dataview v0.5.41
5: Obsidian TODO | Text-based GTD v0.2.7
6: LanguageTool Integration v0.3.0
7: Excalidraw v1.7.13
8: Kanban v1.3.15
9: Extract url content v0.12.1
10: PDF Highlights v0.0.4
11: obsidian markmind v1.5.4
12: Style Settings v0.4.10
Custom theme: for cosmetic issues, please first try updating your theme to latest. If still not fixed, please try to make the issue happen in the Sandbox Vault or disable community theme and snippets.
“### Toyota Auris” is not formatted as Markdown. This happens in longer documents very often. The first part is well formatted, then a part is only black (not formatted as markdown), after some of this not formatted lines, the formatting works well. It only happens in ‘source mode’. After reloading obsidian the error is gone…
When it happens I will add some further screenshots
Take a look on the screenshot after only reloading obsidian. In the first screenshot the heading ‘### Toyota Auris’ is shown as normal text in black and white. After reload it is correct shown as heading (h3)
Obsidian loads documents in parts as they are scrolled into view. Sometimes when you scroll (most often in longer documents) you will see unstyled text briefly before it is rendered. It seems yours is getting stuck in that state sometimes.
Do you need to reload Obsidian to fix it or can you just reload the note (by going to a different note and coming back)?
Use the default theme, use restricted mode (no third party plugins). Post a screen recording of this happening and attach a copy of file that is causing this.
