Running Mac Obsidian 0.14.15 with the legacy editor and entering the following Markdown content:
<div class="myClass">
*Emphasized* text.
</div>
Given that Obsidian wraps content in div blocks, and per example 108 in the CommonMark specification, the above content should be rendered into HTML as:
<div>
<p><em>Emphasized</em> text.</p>
</div>
</div>
Instead of the expected result, Obsidian is creating two div blocks. One contains the raw HTML and the other holds the rendered Markdown
<div>
<div class="myClass"></div>
</div>
<div>
</div>
This can be easily seen using the developer tool’s element inspector (CMD+OPT+I)
