This can be reproduced in the sandbox in a new page with the following content:
Headline 1
Headline 2
# snippet Headline #1
Note that this appears to fold up to the L1 header in the snippet when not in reading mode. Operating in reading mode appears to fold all content correctly on my attempt.
Yes.
All appropriate content in section under the header is folded up, independent of the markdown content in the snippet.
Content under the header is folded up dependent on the content of the snippet, eg. if you are folding a header at the same level or that is a subheader to a header written in the markdown code snippet, you will fold up to the header in the code snippet. This leaves the codeblock half-rendered.
Obsidian version: v1.5.12
Installer version: v1.5.8
Operating system: #1 SMP PREEMPT_DYNAMIC Debian 6.6.15-2###2 (2024-03-19) 6.6.15-2###2-amd64
Restricted mode: onRECOMMENDATIONS:
Note: I run a corporate linux distribution based on debian and have redacted internal codenames above with ###
. This should be somewhat equivalent to Debian testing. This is also operating under a Chrome OS Linux VM through the system-provided integration, though, ideally, this shouldn’t make a difference…
See these screenshots:
Unfolded:
Folded:
Folded (reading view):
