On the Android app there is currently only 3 pre-defined ways to sort vault contents: by name, modified time, and created time. There is no way to manually re-arrange this list if a user wanted a certain note always at the top, bottom, or just a custom order of the list.
I think functionality to allow manual re-arranging of notes and folders via drag and drop would be the simplest solution to this. Also the most common workflow for this type of feature in other apps.
n/a
n/a
