I have a ton of old paper documents I’d like to digitise and keep on my computer, and Obsidian sounds like a great way to manage, categorise, OCR and search.
Some of the things I’d find useful:
- Import and categorisation of scanned documents
- I’d like to take photos of the documents and just drop into Obsidian and have it auto-sort for me
- Metadata extraction
- Auto-tagging
- OCR
- Handwriting support
- Multiple language support
- Extensive PDF support
- current OCR plugins I tried don’t handle my PDFs at all
- Semantic search
- I’d like to ask Obsidian “get me invoices between 2010 and 2018” and have it return all the PDFs as a data view or a table
- Maybe a possibility of encryption of more sensitive files
There are some plugins that provide bits and pieces but I haven’t found a comprehensive solution that works good.
What do you think, do you need something like this?
