Use case or problem and Proposed solution
- Suppose I created a vault at
/some/bad/path/have/a/Obsidian Vaultand used Obsidian to open it. - After some time, I think the path is not good, I’d like to:
- rename the vault path to
/some/bad/path/have/a/Health Vault - change the vault path to
/path/to/My Notes/Health Vault
- The present method is:
- manually move folders in explorer
- delete the old vault in vault panel
- open the vault of the new path
- This process might be improved in the vault panel, providing a easier operation to conveniently manage, rename, move the vaults.
- Sure the Vault Panel might have big change in the future, considering some users might have a few dozens of vaults after years’ usage.
- So I just hope the management feature being considered in the future design.
Manage manually.
