after typed “showLegend: true”, i have tried legendTitle, legendLabel, ect…
make labels in my legend have the actual labels. right now, it says that every line color is “untitled” and i don’t know how to add labels.
What are you using to make these graphs? “charts” “obsidian-tracker” … ? (There are a bunch of others; I do not know all the names.)
i’m using obsidian-tracker
Looking at the documentation for input parameters for obsidian-tracker, I suspect that datasetName
is what is actually making the legend labels. For each searchTarget
in your graph, make sure you also have set a datasetName
The page I linked before also shows which “legend”-related options exist. Good luck!
oh this helped, thanks! do you also know how to change the size of the graph to allow the full legend to be shown?
It looks like there are settings for “legendPosition” and “legendOrientation” - I do not know if either of those would help. To make the whole graph bigger there are “fitPanelWidth”, “fixedScale” and “margin” parameters which all go before the graph type. I like setting fitPanelWidth: true
for my line graphs, maybe that will work for you?
