Make math expressions highlight-able with `==`
This was previously a bug report. Move requested by a moderator.
Currently math (MathJax) expressions are not highlighted when surrounded with ==.
Example code:
==Sample text $R^n$ Sample text $Sample \space math$ Sample text==
Screenshot of example code:
Supporting highlighting inside MathJax is of course crazy. But support for highlighting whole MathJax expressions seems like a reasonable possibility.
Not yet found. Suggestions are welcome.
Actually, inline expressions are highlighted, but only in read mode.
Probably with some clever CSS snippet you could potentially get the same result on edit mode.
I swear it didn’t before the last update, maybe I missed it. Still, only covers the same height. Doing something higher than regular text results in weird looking highlights. Even without \displaystyle I can still see the tips of integral limits outside the highlight.
Example:
==Sample text ${\displaystyle \int_{0}^{1}f\left(x\right) dx}$ Sample text==
==Sample text ${\int_{0}^{1}f\left(x\right) dx}$ Sample text==
Example result screenshot
Maybe it’s better that way, not sure. IMHO highlighting the whole math block would be better.
And it would be nice if it worked in live-preview too.
I think the main issue is how you seamlessly transition between the single line highlight and the equation when it is wider than the text line, in my opinion, a different highlight width is not very eye-pleasing.
Anyway, I did some tests, which I hope is what you were expecting.
Latex method 1
If you want to highlight entirely the latex block you could use the \bbox command documentation), for example:
\bbox[olive]{\int_0^1 f(x)\;dx}
However, the available color options are very little and of course, if you change the obsidian theme the colors won’t match anymore.
Latex method 2
A more appropriate solution, but still a workaround, is to use the Extended Mathjax plugin which allows you to add a global preamble to all latex blocks.
In this way you can specify a custom color and, if you ever change the theme, it allows you to change all the equation highlights at once.
If you choose to do so in the preamble you need to add:
\definecolor{yourNewColor}{rgb}{0.48, 0.48, 0}
Unfortunately, I didn’t find a way to change the transparency supported by mathjax.
In the equation you will have to use \colorbox{yourNewColor}{yourText} intead of \bbox[]{}; keep in mind that in order to write an equation inside \colorbox you need to enclose it in \( \), like so:
==Sample text $\colorbox{yourNewColor}{\( \displaystyle \int_0^1 f(x) \;dx \)}$ sample text==
You could also create a custom macro, for instance by adding \newcommand{\highlight}[1]{\colorbox{yourNewColor}{$\displaystyle #1$}} in the preamble you can simply use the command \highlight{} to get an equation highlighted.
CSS fix
Only after fiddling around with latex, I decided to try to make a snippet and although my CSS knowledge is very basic it was easier than I expected.
There is probably a better way but it seems to work fine, both in edit mode and reading mode the equation is completely highlighted.
/* Replace default highlight with background color */
.MathJax{
    background-color: var(--background-primary) !important;
/* Highlight all mathjax block */
.MJX-TEX{
    background-color: var(--text-highlight-bg);
It also works for equation blocks
If you don’t want this behavior you can edit the snippet as follow:
span.math-inline .MathJax{
span.math-inline .MJX-TEX{
I’d like to add that math highlighting works on the Android version of Obsidian in both Live Preview and Reading Mode for inline MathJax statements by default, however block statements remain unhighlighted:
The latest to date version from Play Market certainly does not support highlighting in Live Preview. At least for me.
I know this is old, but i wanted a way to have highlight show in live preview as well but sadly the mathjax elements do not get wrapped with any mark tag when in live preview:
The best i could do with CSS was highlight every mathjax block if, in the same line, there is a highlight (even if it does not contain the math block itself)
Figured i’d share this, but for a true implementation either native support is required or a plugin that detecs highlighted blocks and wraps them with a special tag to then style with css
/* Remove highlight from all MathJax by default, idk if it's truly needed */
.markdown-source-view .math mjx-container {
    background-color: unset !important;
/* Highlight math only when it shares a line with a highlighted span */
.markdown-source-view .cm-line:has(.cm-highlight) .math mjx-container {
    background-color: var(--text-highlight-bg) !important;
Reading view is fine but i mostly use live preview for the convenience (and it also does not highlight the $$<content>$$ blocks when written like this: ==$$<content>$$==, as far as my testing goes at least)
