pres
April 30, 2024, 4:33pm
1
I met a minor software issue here on MacOS, I don’t know whether other OS having same issue. When I adjust window size or I pull the developer tool, the top left three buttons(close, minimize, expand) float to the corner. And I reopen it, it turns normal.
Y
MacOS
uhm… does this happen in the sandbox vault?
Follow this giude:
Troubleshooting Guide
Search before posting
Before opening a new bug report, please try searching the whole forum for duplicates. It really helps us.
Troubleshoot Instructions
In order for us to fix a bug, we need reliable and consistent steps that cause the bug every time.
If something looks wrong, first make sure you are using the latest Obsidian version and that your installer is up-to-date. The app and installer versions don’t need to match, but they shouldn’t be too far apart.
The instal…
pres
April 30, 2024, 7:17pm
3
sorry bother here, I found out that is the plugin style settings causes this problem
Thanks, send a bug report to them.
