macOS Traffic light controls are vertically scaled in light mode
Themes tested: default, Minimal
Appearance > Base color scheme - set to Light
Did you read and follow the Troubleshooting Guide ? Yes
See Dark mode version above
Obsidian version: 1.15.1
Installer version: 1.15.0
Operating system: Darwin Kernel Version 27.2.0: Wed Oct 14 23:44:56 PDT 2026; root:xnu-13432.41.4~25/RELEASE_ARM64_T6041 27.2.0
Catalyst license: insider
Insider build toggle: on
Base theme: light
Community theme: Minimal 9.1.4
Snippets enabled: 1
Plugins installed: 25
Plugins enabled: 19
1: Style Settings v1.0.9
2: Calendar v1.5.10
3: Minimal Theme Settings v9.0.0
4: Periodic Notes v0.0.17
5: QuickAdd v2.33.1
6: Copy Block Link v1.0.4
7: Linter v1.35.0
8: MetaEdit v1.11.0
9: Dataview v0.5.68
10: Advanced URI v2.2.1
11: Templater v2.26.0
12: Pandoc Plugin v0.4.1
13: Share as Gist v2.0.1
14: Heading Adjuster v1.6.0
15: Text Generator v0.8.7
16: Tag Wrangler v0.6.5
17: Outliner v4.10.2
18: Open in Marked v1.2.9
19: Tasks v8.6.0
Strange, Can you try the sandbox vault?
I don’t think they are actually squished. It’s the illusion you get when the glass highlight (the crescent shapes) mix with the light background. Having said that, they do look like the wrong set of graphics – light mode uses different ones, with a darker outline, as seen here, for example:
