Create a new file and enter text in a RTL language such as Hebrew, Arabic, etc.
Navigate through the RTL text using the right/left arrow keys - works as expected.
Hit ⌘+→ (right) to return to the line beginning (like “Home” key) - works as expected.
Hit ⌘+← (right) to return to the line beginning (like “End” key) - does not work as expected (cursor returns to line beginning instead of line end)
Remarks:
If the text is in English (or other LTR language), the behavior is correct (even in Editor is set to RTL).
End key works as expected (when a full keyboard is used).
Did you follow the troubleshooting guide? Y (sandbox vault, community plugins turned off, no CSS snippets installed)
⌘+→ should behave like the Home key - works.
⌘+← should behave like the End key - does not work.
Cursor goes to line beginning instead of line end when hitting ⌘+←.
Obsidian version: v1.5.12
Installer version: v1.4.13
Operating system: Darwin Kernel Version 23.4.0: Fri Mar 15 00:12:41 PDT 2024; root:xnu-10063.101.17~1/RELEASE_ARM64_T8103 23.4.0
Catalyst license: none
when hitting Command (⌘) + Left, the typing cursor goes right to the start of line while it should go left to the end of line for RTL languages
when hitting Command (⌘) + Right, the typing cursor goes left to the end of line while it should go right to the start of line for RTL languages
Obsidian version: v1.7.4
Installer version: v1.6.7
Operating system: Darwin Kernel Version 23.6.0: Mon Jul 29 21:14:21 PDT 2024; root:xnu-10063.141.2~1/RELEASE_ARM64_T8103 23.6.0
I am looking again at this bug report.
Given that the hotkeys are tied to directional arrow keys, would it make sense that regardless of RTL or LTR they move the cursor in the direction of the arrow?
What do they now?
How does an apple native app behaves?
Also there is another very related issue which is:
if you put the cursor at the beggining of a line and then press left arrow
(which should navigate left through the line’s letters) it instead taks you to the end of the previous line).
Here is a gif screenshot of this two problems:
Please fix it, it’s really really hard to work like this.
