- Open the Sandbox Vault with the macOS client
- Open the Formatting > Task file
- Move the cursor to the middle of any of the Task bullet points
- Press ^A (Ctrl+A)
The cursor should move to the beginning of text (just after the checkbox). The checkbox should still be rendered as a UI widget rather than as raw Markdown.
This is the behavior you get when pressing ⌘+← (command left arrow).
The cursor moves to the beginning of the line in the raw Markdown file. The checkbox is visible as raw markdown (- [ ]
) and not as a UI widget.
Obsidian version: v1.4.16
Installer version: v1.4.16
Operating system: Darwin Kernel Version 23.0.0: Fri Sep 15 14:41:43 PDT 2023; root:xnu-10002.1.13~1/RELEASE_ARM64_T6000 23.0.0
Legacy editor: off
