[MAC] "undo" command does not work in title field
Enter text into the Title Field and then attempt to perform an “undo” with key combination Command-Z and/or menu “Edit”, “Undo”
Last edit should be reverted.
Menu item “undo” flashes but no “undo” operations are performed.
  • Operating system: macOS Catalina 10.15.5
  • Obsidian version: 0.6.7
  • Using custom CSS: No
It is a trivial bug but a new user demoing the product may encounter it very quickly.
This is a mac-specific issue. We’ll look into it.
Will be fixed in 0.7.2
