DevTools failed to load source map: Could not load content for app://obsidian.md/luxon.js.map: System error: net::ERR_FILE_NOT_FOUND
I am aware that this issue is not coming up when community plugins are disabled, but to my understanding this is obsidian internal functionality that the dataview plugin accesses.
- Install Dataview plugin
- Create a Dataviewjs query that uses the luxon “library” ?
This is from my snippet. I didn’t create it, I found and copied it from the preview thread.
var t = dv.current().file.day ? dv.current().file.day.toISODate() : luxon.DateTime.now().toISODate();
// Obsidian uses moment.js; Luxon’s format strings differ!
var format = app['internalPlugins']['plugins']['daily-notes']['instance']['options']['format'] || 'YYYY-MM-DD';
No warning in terminal.
I haven’t seen it produce anything problematic, but in the terminal it outputs the warning/ error:
- Operating system: Windows 10
- Debug info:
Obsidian version: v1.0.3
Installer version: v0.15.9
Operating system: Windows 10 Pro 10.0.19044
Legacy editor: off
Base theme: light
Snippets enabled: 1
Plugins installed: 43
Plugins enabled: 35
1: Checklist v2.2.10
2: Copy button for code blocks v0.1.0
3: Find orphaned files and broken links v1.8.0
4: Folder Note v0.7.3
5: Meld Encrypt v1.6.2
6: Mind Map v1.1.0
7: Obsidian TODO | Text-based GTD v0.2.7
8: Table of Contents v0.1.3
9: Obsidian Git v2.8.0
10: Advanced Tables v0.17.3
11: Admonition v9.0.5
12: Dataview v0.5.47
13: Editor Syntax Highlight v0.1.3
14: File Tree Alternative Plugin v2.2.4
15: Natural Language Dates v0.6.1
16: Tag Wrangler v0.5.4
17: Auto Link Title v1.2.5
18: Dynamic Table of Contents v0.0.27
19: Note Refactor v1.7.1
20: Update time on edit v1.1.2
21: Outliner v4.1.1
22: Calendar v1.5.10
23: Tasks v1.16.0
24: Cycle through Panes v0.1.0
25: Sortable v0.2.6
26: Creases v0.6.5
27: Excel to Markdown Table v0.4.0
28: Meld Calc v1.0.2
29: Obsidian42 - BRAT v0.6.36
30: Query Control v0.5.0
31: Apply Patterns v2.1.1
32: Linter v1.7.0
33: QuickShare v1.0.1
34: Pane Relief v0.4.1
35: Gitlab Issues v0.1.4
I found an old issue (2017) in the moment github, where the luxon.js.map wasn’t correctly bundled. Something similar might’ve flared up again. But I don’t have any experience in JS so reporting is all I can do here.
