I’ve updated the css for callouts with the following code on my MacBook Air:
.callout[data-callout=“clipboard”] {
–callout-color: 106, 134, 149;
–calout-icon: lucide-clipboard;
border: 1px solid rgba(255, 255, 255, 0.09);
border-radius: 10px;
box-shadow: -10px -10px 30px rgba(255, 255, 255, 0.10);
Everything works the way it is supposed to except the callout still shows the pencil instead of the clipboard.
Any ideas?
holroy
2
Add another l
in --calout-icon
, might do the trick.
ariehen
3
Also, “clipboard” should be "clipboard"
(notice the quotes) and the callout-icon part should have two dashes --callout-icon
as noted here.
CSS is unforgiving
holroy
4
I think those two issues are formatted as such by the forum software, since they neglected to put the css into a code block.
ariehen
5
Probably, but just wanted to add it
Thank you.
Late night and that was killing me. The missing L was the issue.
Yep. That was all the forum format.
system
Closed
8
