Low workspace start-up time
When I start Obsidian at first time(in a day), the loading time mainly spent on the workspace. So I wonder what’s the problem, my workspace is not so big, which only has 3k+ notes and lots of pictures.
check start up time recorder.
Obsidian and Installer are both old.
Download a new build of Obsidian, which will include a new Installer, and reinstall the app. Your vault will be preserved. Do the load times improve?
I’ve re-installed the latest version, and try to startup again.
the result is below, it seems like the issue have been solved.
I’ll try again at tomorrow to verify it.
Thanks for your help
for this day, the record shows that it cannot solve my problem
Will the results be the same in Restricted Mode?
In my experience, some plugins affect sections like “Workspace” anonymously, and this doesn’t count towards the time of the plugin itself. In my case, disabling or lazy loading certain plugins improved “Workspace” times.
In other cases, disabling a plugin can affect “Workspace” or “Vault” times just by having the associated file in the /.obsidian/plugins folder.
Although the thread below references users of macOS, perhaps the same underlying issue is relevant to Windows as well:
Does apply to Windows … see:
thanks again, I see that the creator said this problem should be solved at V1.8.8
I’ll wait for this update, and check its effect.
I disabled most of my plugins from 3rd party and restart, the result shows no improvement.
Then, I open the “safe mode” and restart, it makes sense.
I’ll do detailed experiment later.
