Yes, each note in the queue has yaml data indicating when it’s due next. There are shortcuts to space them out in different ways, and you can also just write in a date.
I use this for notes and short essays I’m working on but not sure if they’ll evolve into full scale writing projects. Each day I have a queue of notes due that day. I work on the ones I want to work on; if it was productive I mark as “hard,” which makes the due date relatively soon; if not, I mark as “easy,” which makes due date relatively distant. If I didn’t work on something I mark it as “good” which spaces it out a moderate amount.
I have limited time to write every day—ideally 30-60min, usually more like 20-30min. I spend about half of that working on this queue and half on more “active” long term writing projects. I like that, even with my limited time, this system allows me to work on several ideas at once (albeit very slowly), which helps me stay creative and not be bored with my main project.
