How to add a tag such as ‘Treatment Planning’ instead of using underscore between the two words? Thank you
The most common alternatives is to either remove the space, or use a substitute character:
TreatmentPlanning
aka CamelCaseTreatment_Planning
Treatment-Planning
And so on, and so forth. It’s mostly a matter of preferences from here on in. Some characters might pose different problems though, like .
, could possible do some shenanigans, and possibly /
or \
Either way, I don’t think there is a way to actually preserve the space, unless you potentially find some strange unicode character which is both legal to have as an identifier and visually appears as a space character…
