- Copy the long mermaid code from here
- Paste into a mermaid code block in Obsidian
- Zoom in using the Pele controls to make the chart bigger
Did you read and follow the Troubleshooting Guide ? [Yes]
See multiple labels above each other like in the Pele playground.
You can barely visibly fit one label.
Obsidian version: 1.15.1
Installer version: 1.15.0
Catalyst license: insider
Insider build toggle: on
Plugins installed: 0
Plugins enabled: 0
You can use a CSS workaround like this:
.pele-timeline {
min-height: 400px;
But it would be nice if there was maybe an expand button or a resize handle?
