Obsidian version: v1.1.9
Installer version: v1.1.9
Catalyst license: vip
Legacy editor: off
Yes I can reproduce. When I test it, it works with an html linked image. It also works with an absolute file:///path image. But not a local vault image.
I don’t personally know if it supposed to be supported. Do you know of any example or documentation that suggests this format is supported using local vault paths? Or did it used to work for you?
I’m not exactly sure what you mean. Everything functions correctly, as in there is an image and there is also a functional link. So it’s clearly supported. It’s only the visual output which is a bit messed up.
You can’t click on the image as a link either. Only the little arrow. The fact it works at all might just be a coincidence. I’m not getting “clearly supported” vibes.
I think we’re talking about different things. Your question which I quoted was about a local vault path being recognised. My reply was to say that the local vault path is indeed being parsed and turned into an image.
In the help docs there is an image with a local path (“og-image.png”):
And the CommonMark spec says that this is valid Markdown to encapsulate an image with a link in this way, so going back to my first post it looks like there is a bug with the conversion to HTML elements in the reading view.
Any response from the Obsidian team? This is a nice, easily replicable bug report, using the sandbox vault, with direct links to the applicable CommonMark spec.
