Hi Everybody,
Since the last year, I have begun to use obsidian.md as my notetaking software. I found a way to combine different aspects of notetaking in a workflow, at least for my notetaking style. They are
- Goal and project management
- Journaling
- Personal knowledge management (PKM)
- Review.
I call it LMS (Life Management System), as it handles the most important parts of my life.
The main reference to build this workflow are:
- Progressive summarization from Forte Labs
- Zettelkasten from Niklas Luhmann
- Linking Your Thinking
- August Bradley - Life Design - PPV
Maybe you are also trying to combine different approaches in your notetaking workflow, or just searching for a vault template, which provides sufficient features out of the box. My templates and workflow may give you some help. So, I decided to share my vault template and create guidance for the workflow.
The template vault
The template vault is hosted on GitHub. laozhou-in-germany/Chens_LMS_Public
Most files in the vault are extracted from my private vault. I optimize them constantly during my daily use. It will be for a long period of time a work in progress.
The file structure
000_Drafts:
Default folder for note, drafts of all possible note types, sorted later. -
100_Goals_Projects:
Pillars, value goals, outcomes & projects, also routines and mindsets -
300_Journal:
Daily routines , events, meetings and other journal elements -
500_Knowledge_Management:
Literature notes, atomic notes, evergreen notes and topics -
700_Plan_Review:
Plan, Review and workspaces -
900_Supporting_Files:
Templates, Config, Help…
The workflow
Note types
Coming soom.
Linking with links and tags
Coming soom.
Handling literature note
Coming soom.
Handling atomic note
Coming soom.
Handling evergreen note
Coming soom.
Handling topic note
Coming soom.
