Live Preview: Text select drag and drop of text is incorrect when going from or to a location with markdown markers
Select ** at the end of some bolded text.
Move the selection / highlight to the right in the same sentence.
The two stars go where they should.
The two stars go 4 characters more to the right, relative to where they should be
Obsidian version: v1.9.12
Installer version: v1.8.9
The formatting seems to be rendered before moving the selected text:
https://discord.com/channels/686053708261228577/1286754583846064138/1420777919634083892
Are you moving the selection highlight, or moving the selected text? Either way, how are you doing it? Shift →? Cut & paste? Something else?
Very interesting. I wonder if you are the first to spot this. This is a much broader problem.
Obsidian_XNvB6SHhkn
  • In Obsidian v0.13.14 or v0.13.19, open new document in “Live Preview” mode.
  • Paste following text into Obsidian (without surrounding code-block backticks).
permanent line above
moved line 1
moved line 2
[markdown](link)
permanent line below
  • Select “moved lines” including initial line-break after “permanent line above”.
  • Drag and drop them before “permanent line below”, i.e. after markdown link from which only “markdown” is visible in live preview.
Dropped text should is intended and expected to be pasted after the link.
[markdown](link)
moved line 1
moved line 2
Dropped text is pasted between visible and hidden part of link.
[markdown
moved line 1
moved line 2](link)
Current workaround
  • select the text to be dragged.
  • cut it by Ctrl+X
  • click to target location (This places cursor correctly after markdown link.)
  • paste the text by Ctrl+V
  • Operating system: Windows 7
Ok I can reproduce.
