Live Preview: not working, despite resetting editor mode, disabling plugins etc
Using the editor, set to live-preview, however, I stil get the Edit / Viewing behaviour, and toggling live-preview doesn’t do anything, either.
Using editor in live-preview mode.
it is all configured for live-preview, but it operates in the legacy mode.
  • Debug info:
    Obsidian version: v0.13.23
    Installer version: v0.13.23
    Operating system: Windows 10 Enterprise 10.0.19044
    Legacy editor: off
    Base theme: light
    Community theme: Sanctum
    Snippets enabled: 1
    Safe mode: on
Custom theme: for cosmetic issues, please first try updating your theme to latest. If still not fixed, please try to make the issue happen in the help vault or disable community theme and snippets.
The issue does not occur in the Help vault, as this test was advised in another bug report. Toggling legacy mode on/off and rebooting obsidian does also not help.
what happens if close all the panes and open a new one?
Thanks for the reply.
Depends on the note. Some notes will work in live-preview, others won’t. Haven’t been able to discern a pattern, which will work or won’t work.
Please, post a screen recording of this happing in the help vault.
Is there a way to “reset” Obsidian, as in cleaning a browser? I know and tried (see above) to re-enable safe-mode for plugins, but this doesn’t resolve the issue. In the help-vault I have no issue, so I’m thinking it must be something related to what I did in modding Obsidian, that isn’t resolved through safe-mode-ing plugins.
Done some more testing. Deleting everything from my Vault’s .obsidian folder did not restore functionality for existing note files.
Newly created notes did have the desired toggle-behaviour for live-preview though.
This indicates to me something in the metadata of the existing notes must be wrong, maybe through some plugin influence? Is that feasible? I’m looking into it now.
EDIT: Okay, it is related to the yaml front matter. When copying frontmatter from docs it immediately starts working again. When using my templated frontmatter, it doesnt. Limiting it down, it’s the dashes
that cause the issue. Really strange, my — work for
style lines, why wouldn’t they work for frontmatter syntax. Either way, I’ll stop investigating this now.
Found the problem after all. There was one SPACE after the final delimiting dash. My yaml was sth like:
DASH DASH DASH\n
yaml content
DASH DASH DASH SPACE \n
and that crahsed the parsing of everything after that.
