Live preview mode + <% in code block
I have a code block
```bash
git log \
  --graph \
  --abbrev-commit \
  --pretty=format:'%Cred%h%Creset -%C(yellow)%d%Creset %s %Cgreen(%cr) %C(bold blue)<%an>%Creset'
…and then some regular text below.
Because of the <% in the last line the Live Preview mode renders the regular below this code blocks as if it’s part of the code block.
If I switch to Reading View the Markdown rendering is correct.
  • surround the code block with <code> tags instead of triple backticks
Please follow and include the entire template when submitting bug reports. Thanks.
Your exact code block looks alright over here in both Live Preview and Reading view (Obsidian v1.5.3).
Obsidian_k6nJ40iZza
I can’t reproduce. post a screen recording of this happening in the sandbox vault.
I have the same problem.
Perhaps it comes from this issue but I have no knowledge to fix it…
スクリーンショット 2024-02-18 15.01.29
スクリーンショット 2024-02-18 15.01.57
Yeah, it seems like a Templater issue.
CleanShot 2024-02-18 at 19.46.17
Yes that seems to be it, thank you!
I think I’ve found the relevant issue on the Templater repo.
Disabling Templater’s setting “Syntax Highlighting on Desktop” renders the note as I want it to, at the cost of not having syntax highlighting for Templater templates of course.
