Live Preview: a line starting with ">" inside a code block in a quote is drawn as a nested quote
  1. Paste this into a note:
    > line one
    >> line two
  2. Look at it in Live Preview and Source mode, then in Reading view.
Yes (reproduced in the sandbox vault, no community plugins).
Everything between the fences is code, so the third line is the code line > line two, as Reading view shows: a quote that holds a code block of two lines, line one and > line two.
The editor reads the second > of the third line as a nested quote, even though the line is inside the code block:
  • Live Preview draws a second quote border on that line, hides the >, and shows only line two.
  • Source mode styles the line as a level 2 quote.
	Obsidian version: 1.15.0
	Installer version: 1.14.4
	Operating system: Windows 11 Pro 10.0.26300
Sandbox vault, no community plugins, default theme and settings.
This shows up when quoting code or a log whose lines begin with >, such as an email reply or a shell prompt.
Related, fixed in 1.9.3: Angular brackets “>” will mess live preview of codeblocks in quotes and callouts, about < in a quoted code block.
