Lists (ul and ol) inside code block are broken
  • Create code block
  • Start a new ul with "- " or ol with "1. " inside the code block
  • Press enter/return to start a new line
Yes.
I would expect either the ul/ol to behave as they do outside of the code block, and continue the ul/ol with a "- " or "2. " on the new line OR for the new line to start without anything in it
The new line starts with a blank indent the length of the ul/ol syntax (two-space length and three-space length respectively)
Obsidian version: 1.12.7
Installer version: 1.12.4
Operating system: Darwin Kernel Version 25.4.0: Thu Mar 19 19:33:33 PDT 2026; root:xnu-12377.101.15~1/RELEASE_ARM64_T8140 25.4.0
Catalyst license: supporter
Plugins installed: 1
Plugins enabled: 1
1: Maps v0.1.6
I’m pretty sure this was broken less than a year and a half ago, and I’ve just taken a long time to get around to making a bug report for it, since it’s a relatively easy-to-fix-and-forget-about annoyance in my daily work routine. I know that the behavior prior to breaking was that the ul/ol would continue inside the code block like it did outside of it, but I also understand if it makes more logical sense to not do that inside a code block.
I have reproduced this bug on various devices (Mac, PC, iOS), including in vaults without any community plugins - the device I’m writing this bug report on just happens to have one single plugin on it right now.
I don’t consider this a bug.
If are writing anything except MARKDOWN, doing what you suggest is gonna be pretty annoying to the users.
We should not even add the spaces.
Yep, that’s what I mention in the second part of the ‘Expected Result’ part of my post—I understand that since it’s a code block it might not need to format as a list, even though it did in the past. Either way, though, I think adding the spaces is still a bug?
thanks, I will write the BR for that.
