Links within the current note
I don’t know if that’s possible. Maybe you should ask in the #general channel.
Robert, I just discovered that you can do this:
[[note name#header|some text]], which will then display as some text. Note the pipe character between “header” and “some text”
I believe that’s what you meant with your last question?
Just discovered the ability to link to headers within the document and piping to name it. I’m in love with this baby.
Ray
Installed today, this was the one feature I was missing. Glad to hear you’re on it! :slight_smile:
Thanks so much for implementing the ability to jump to headings – Obsidian is wonderful.
This is amazing. I am 99% happy with Obsidian. It’s seriously awesome, in the original meaning.
Yes, glad that this feature exists!
I have noticed that block links within a note don’t work beyond a certain point if the document is very long. When clicking ^ to scroll through the note the pop-up display ends prematurely. This problem did occur with external notes but was fixed.
This is not a bug ^ is not expected to provide an complete list of all possible blocks. It’s just autocomplete suggestion.
