In Mermaid it’s possible to create a node that links to a file, for example:
flowchart TB
node("Example")
class node internal-link;
However with the method it seems like you can only link to the full text of the node.
I was wondering if there was a way to have a display text, and a file separately.
Example / Proposed solution
Example 1:
flowchart TB
node("This is an example||example")
Example 2:
flowchart TB
node("This is an example")
class node internal-link-Example;
In these examples the text of the node would be “This is an example” - but the link would refer to the “example” file.
I would propose something like the second example, because the first one example messes with vanilla Mermaid and literally displays “This is an example||example”
The current workaround is to add extra nodes with just the exact text for linking purposes, but it adds extra unnecessary nodes to my diagram
