Yes, and I did this in a sandbox.
Discovery Background
- I have files where I’ll embed certain headers of other files. One of which is in a Q&A format on different topics, and I simply label each question sequentially under each topic. In Obsidian, I used the full path to embed what I want (first example in screenshot).
- I use Quartz as a static site generator. It could not resolve the full path with more than one step, but if I shortened it to the lowest heading, it would embed it on the site.
- I was using the Broken Links plugin and noticed it considered references to headers a few levels deep as broken, but if I removed the higher level headers, it was considered fixed.
- I tried to “fix” these broken links by manually selecting the lower level heading.
- I’d expect that full paths would be considered links (but I don’t know if that issue comes from the plugins themselves or how they’re interpreting Obsidian).
- I’d expect that if I chose to select a specific lower level heading without going through all of the upper level headings, it would be able to reference/embed the correct one.
- A side by side of the Test file with headers and a second file I’m trying to embed header references into.
- If you directly reference a lower level heading, Obsidian will always reference the first heading called that in the file.
Obsidian version: v1.7.4
Installer version: v1.6.5
Operating system: Windows 11 Pro 10.0.22631
Catalyst license: none
