I have this folder called “_Inbox” which is where I dump all my notes that I then process when I have the time.
I created a note to test anchor links, but noticed that they don’t work at all, meaning when I hit # to show me all the headings, it says “no match found”
I clearly have 2 headings:
Then I thought that maybe the issue was the folder itself, maybe the underscore, so I opened another folder called “Other” and to my surprise, I can see both headings when I type #:
Now for some odd reason, when I create the links, one shows me the original folder, the other doesn’t:
EDIT: I noticed that if I remove the path from the link and just have the note’s name, it will work:
Note: When I create the links by picking the note’s title when I add [[ (so basically when it includes the path), what happens is that when I click the link, it creates a new empty note with the title “Heading 1” or “Heading 2”.
But if you try to search for an anchor after the displaying text [[Internal links|custom display text#]] it will return no results, because the # is interpreted as part of the displayed text.
