Links to external files do not work in callouts
  1. Create a link to a document in my file system:
  2. Click the link. The file opens as expected.
  3. Put the link in a callout:
  4. Click the link in the callout. Nothing happens.
Y
The linked file should open.
The linked file does not open. Nothing happens. Other kinds of links work fine (e.g. internal links, URLs). Only external links to files do not work.
Obsidian version: v1.4.16
Installer version: v1.4.13
Operating system: Windows 10 Home 10.0.19045
Catalyst license: none
Legacy editor: off
I’d double check your path syntax is correct. Moving the cursor out of the callout (so it renders) and clicking the link: both of these work for me.
Screenshot 2023-10-25 073738
Screenshot 2023-10-25 074321
sublime_text_0FiNhaslWA
external link to file →
[link text](file:///C:\Users\USER\Desktop\file.txt)
[link text](<file:///C:/Users/USER/Desktop/file with spaces.txt>)
[link text](file:///C:%5CUsers%5CUSER%5CDesktop%5Cfile.txt)
The slashes can be forward or backward here; It doesn’t seem to matter. I wasn’t sure because I mainly use a mac which uses / for paths.
Hi. Is that file:/// documented somewhere? You seem to provide useful information about it.
It’s mentioned in the https://help.obsidian.md/User+interface/Drag+and+Drop section, but the specifics I picked up from the forum or trying things out.
  • Hold Ctrl on Windows/Linux or Option on macOS to create file:/// absolute links to those files instead of importing a copy.
You can submit errors, typos, or omissions to the documentation here: https://github.com/obsidianmd/obsidian-help
Yeah, I’m wondering if @blue_emperor tried this link syntax outside a callout, because I suppose ot wouldn’t work there either.
Thanks, this works. Sorry, I thought I had previously tried the correct syntax you show with the file:/// prefix to the file path, but it turns out I was missing a forward slash (I had file://C:/…). Whoops!
