When a link is enclosed with strikethrough formatting (~~[[link]]~~), only the brackets are struck through. The link text is not.
Screenshot is from the demo vault.
thanks
A variant of this bug still exists in the default theme in 1.0.3.
Struck through note links work correctly, but struck through web links don’t. Both in live preview and source mode.
Is there a solution for this? I’m having the same issue.
That’s exactly the one annoying me.
I’m okay with [text](link) not being completely struck through as it only appears when you move the caret there. Otherwise just the text appears and is properly struck through.
But most of the time, I strike external links because there are dead and it’s important for me to remember that they are.
For now the workaround is to surround the link with [] so it shows strikethrough properly. And if you really want to get rid of the [] visually you can also add (dummy link) afterward (of course the link will be invalid, but if you strike links that are dead it doesn’t really matter).
