Links in Properties are not properly recalled
  • Create a file with a List type property with several Links as values
  • in a file that you are linking towards, create the same list type property with different links
  • go back to the first file and click on the linked file in the properties
  • the file you traverse to will have the same links in properties as the file you started from, although it should have different links.
  • Sandbox Vault
  • Linux, Pop OS 22.04. .deb file
  • Obsidian 1.4.16, Installer Version: same
where_are_the_links
