Linking via Block Reference (Block ID, Bookmark) is broken
Settings > Editor > Display > Strict line breaks : Disabled
In Live Preview, type the below into an note past the Frontmatter:
[[#^ref|Link]]
Text before
Source to reference ^ref
text to follow
Y
The Link should take me to the referenced block, and the block should be highlighted
Nothing happens
Obsidian version: v1.11.7
Installer version: v1.6.7
I suspect that the Markdown parser logic has changed to strict double line line breaks, because the following works, but in encapsulates the Text before:
[[#^ref|Link]]
Text before
text to follow
but this only highlights the source properly:
[[#^ref|Link]]
Text before
text to follow
This is not a bug.
A block reference should be placed AT THE END of a block.
A text block corresponds to a paragraph, generally separated from other blocks with blank line before/after (strict line break is different thing)
a block
of text
this
is a
block ^validref
another block
This is not a thing because is a is not block/paragraph.
a block
of text
this
is a ^invalidref
block
another block
