Background:
I work on multiple systems, 97% macOS, but various macOS versions. I wanted to get to know linking to the bottom, i.e. not only be able to link to other md notes, but also to headings and blocks.
Therefore I started to follow examples from the help.obsidian.md page, but I could not get linking to block to work.
To debug and find the culprit / reason, I tried doing the same on multiple macs. These macs run various versions of macOS: Mojave (2 systems), Catalina (1 system), Monterey (2 systems)
Yes I did.
When typing [[name of noteˆ]] I am expecting to see a pop-up with a list of the block(s) in the target note. When doing the same with purpose of viewing the target note’s h1, h2 etc headers everything works as expected.
No pop-up with list of target note block(s)
Obsidian version: v1.3.7
Installer version: v1.3.7
Operating system: Darwin Kernel Version 19.6.0: Tue Jun 21 21:18:39 PDT 2022; root:xnu-6153.141.66~1/RELEASE_X86_64 19.6.0
Catalyst license: insider
Legacy editor: off
Base theme: light
Snippets enabled: 6
Plugins installed: 28
Plugins enabled: 0
Up to today, this issue was limited to my Mac running Catalina. To run an additional check, I fired up my 2013 Macpro (Trashcan) that is running Mojave too, and on that machine, running Obsidian 1.3.7 (installer 1.3.5) the same thing happens.
The unfortunate thing is that I can not:
- reproduce this on all my mac machines
- can not seem to find the culprit of this issue in order to keep working in a reliable way with obsidian
- can not link this issue to Catalina solely because it is appearing on Monterey too
- I have done the test with the sandbox vault on two machines where the issue appears, a 2018 Mac mini running Catalina and a 2013 Macpro running Monterey
=> Please help or point to help on how to solve this issue?
[email protected]
