Linking Obsidian note to DEVONthink
Hello!
Can anybody please explain to me how to use the UUID of a DEVONthink item in Obsidian?
If I take a note, I want to link back to the original document for reference. In DEVONthink I can get the item link, which looks like this: x-devonthink-item://10BA9397-2667-4C62-8959-6E0396521CA9. If I paste this in Obsidian I do not get the linking functionality.
Does anybody know the correct syntax I have to use here, that Obsidian “sees” the link and opens the document in DT if I click on it in a note?
Thanks!
Simply use the item link with standard markdown syntax, i.e.
[DT item](x-devonthink-item://10BA9397-2667-4C62-8959-6E0396521CA9)
Thanks for the fast and helpful answer. Sadly I am not so proficient in markdown and my search in the web produced no helpful result…
Have a nice day!
There is a remarkably easy way to link to the UUID of sources/documents in DEVONthink.
In DT: index your obsidian vault, open the target note, then select the sources/docs you want to link to and Cmd-Alt-Drag & drop them into the note.
Presto! the link(s) show up, properly formatted and named in Obsidian.
(It took me a while to find an answer to this – and it is useful for DT users --, so I’ve crossposted this answer in a couple places here and on the discord server).
Thanks for the tip! I use DT to index Obsidian so it’s a valuable trick for me.
PS: for those who use DT but don’t index Obsidian with it, remember to use ⌘⌥⌃C to copy the item link of the selected item, which is way faster than clicking through menus :stuck_out_tongue:
Umm…WOW. Mind blown.
You know what’s even cooler? When you make this connection on the mac, the hyperlink also works via 1Writer to Devonthink to Go on the iPad! So, essentially, I can dump a bunch of read it later PDFs into Devonthink, read them on the iPad while creating zettels in 1Writer.
DEVONthink item links are unique, so as long as the database is present on a device, DEVONthink will find it, open it, and open the linked item.
Mathematically they are not ( :wink: )
But for real life usage they are.
UUID and Hashes are great solutions BTW…
Thank you for correcting my hyperbole with harsh reality. It’s why I come here.
This AppleScript may be useful. Can be used with a text expander app like Typinator.
tell application "DEVONthink 3"
	set mySelection to selection
	set firstSelectedItem to item 1 of mySelection
	set myString to "[" & the name of firstSelectedItem & "](" & the reference URL of firstSelectedItem & ")"
	return myString
end tell
With this, the backlinks stop working in Obsidian. They only work if the link is using Wiki format, i.e. [[
Hi there. You seem to know a lot about DT and Obsidian integration. I’m new to Devonthink. I just indexed my Obsidian vault, but realized that DT doesn’t pick up my YAML tags. Is there a way around this? I know it picks up inline tags in the text, but is there a way to pick up YAML tags in DT? Thanks so much.
