Linked Mentions of different headers with exact same text
What I’m trying to do:
I am trying to mention a header from another document, however many headers have the same text, example:
here is the text of a document called “document-sama”:
Biggest header
smol header
Biggest header 2
smol header
Biggest header 3
smol header
I want to mention “## smol header” under “# Biggest header 2” in another document, but if I type [[document-sama#smol header]] or if I use the pop-up window and click on the second header
what I know would work:
I want to avoid using “mention block” feature, because it doesn’t look as nice to see those “^761324” after the header.
what I think would work:
The only solution I see if linked mentions were to be the whole sequence of headers such as [[document-sama#Biggest header 2##smol header]]
ok so this can be solved by doing
[[document-sama#Biggest header 2#smol header]]
so if you were searching for the solution, there you go!
Wow, I wonder if that’s intentional behavior or just a happy accident?
Someone asked about this a while ago and the answer was “that’s not supported”.
