Link To Daily Note - Help Please
Hi all I was looking for some help.
I’m still fairly new to Obsidian and I was trying to add a link to my daily note on my home page.
I’ve tried this =link(dateformat(date(today), "DD-MM-YYYY"))
This is the result above (not my daily note link)
This is my Daily Log format that I’ve set in the daily notes plugin.
Could someone help me create the link please?
I’ve also got the natural language plugin installed if that makes a difference.
Thanks.
Do you have the dataview plugin installed? What you are trying to use is a dataview query - it should actually work once the plugin is installed and enabled.
And it should be
=link(dateformat(date(today), "dd-MM-yy"))
