Link all unlinked mentions with one click
+1 please!
+1, would be useful
+1, i could use that.
+1 hope this becomes a feature
I found a plugin called ā€˜Note Linker’. And it works!
basically the title, is very boring link term by term when you have a ton of notes, would be easier if exist a ā€œ'link allā€ button on the unliked mentions
+1, would also love to have an ā€œautomatically link unlinked mentionsā€ option for notes that will be repeatedly referenced.
+1 for a button/function to batch-link Unlinked Mentions of choice, especially if it includes a function to select the ones that are most relevant and skip the ones that aren’t necessary (like a checkbox?). Thanks all.
Just to add another +1 to this, it would definitely be useful, in fact I would go one further and say that it could even be made more useful e.g. link all references to "note 1ā€ or ā€œnote 2ā€ or just all unlinked (e.g I currently have a note which has 352 unlinked mentions, and I would like to only create actual links to one of the twenty or so possible linked pages)
+1 would appreciate this feature
+1 for bulk linking!
+1 for this feature
ADD a button to accept ALL outgoing links. They are pretty accurate. I need a way to accept all
The outgoing links are pretty accurate, i dont need to manually approve them
ADD a button, and dont change what already have!
nil
outgoing links
i got 270 links in my file.
and it is indeep a mirror from another file.
so every time i modified the original file, copy here and need to re-link 270 links.
that’s the problem.
you don’t need it, fine.
the thread shows a lot of people need it.
almost 2 years passed,
nothing changed.
Thank you, we get your point. But please don’t repeatedly reply to this thread. There are many existing Feature Requests, and not everything can be priority. And flooding a thread is not going to make it a priority.
What is the proper way to show support then, if not by replies?
Replying once is encouraged. Replying repeatedly is not.
+1, I’d use this feature.
Manually linking tons of references in a huge vault is too boring.
While everyone is talking on AI, these kind of simpler automations would add much more value.
Hi guys, just came across this thread as I was building an update for my plugin. I released a plugin for this problem about a year ago. Here’s the link to my original post about it. I too was very surprised to see this wasn’t an included feature. I hope you guys can get some use out of the plugin. It’s very basic at the moment, but should address the general use case.
