In many textbooks there are questions that are layed out in the form of lists. Most of the time these lists are numbered, but if the question has sub questions or steps, they are layed out in a lettered list, like this
A)
B)
C)
Adding in lettered lists, that go alphabetically. Upon reaching Z, you could go aa, ab, ac, etc.
It would also be helpful to be able to put a number before this list, so you could have this kind of structure
1a)
1b)
1c)
2a)
2b)
2c)
You can still type this kind of list, it just doesn’t appear the same, nor does it autofill, since it’s just plain text.
I use primarily live preview mode, though I use source occasionally to fix things if they’re being awkward. I should also mention that I primarily use the mobile version of obsidian.
