Before opening a new bug report, please search the forum for duplicates and follow the Troubleshooting Guide.
- We only consider bugs that are reproducible in the sandbox vault or a vault with no third-party plugins/no css snippets/default theme.
- For Linux, we only accept bug reports that are reproducible with our Appimage or Snap package under Gnome or KDE.
- Developer issues with the API should go here
- Themes and Custom CSS issues should go here
- Obsidian Clipper Bugs should be posted here
- Obsidian Importer Bugs should be posted here
any note create some headers, any level
H 1
H 2
after those title in a next line enter . (less than character lowercase o greater than )
. update if I don’t put it on back ticks they are not visible for the bug description. the characters are <o>. I had to use backticks to show them here.
new header
it does not work as a header anymore
remove the and the new header works.
yes
Yes
The header worked in all situation even after
the header is treated as regular text, and the lowercase “o” turns red.
Obsidian version: v1.7.7
Installer version: v1.4.13
Operating system: Darwin Kernel Version 24.2.0: Fri Dec 6 18:56:34 PST 2024; root:xnu-11215.61.5~2/RELEASE_ARM64_T6020 24.2.0
Catalyst license: none
Snippets enabled: 8
Plugins installed: 48
Plugins enabled: 41
1: Advanced URI v1.40.1
2: Banners v1.3.3
3: Advanced Tables v0.21.0
4: Advanced Slides v1.20.0
5: Buttons v0.5.1
6: Checklist v2.2.13
7: Code Styler v1.1.7
8: Diagrams v1.5.0
9: Editor Syntax Highlight v0.1.3
10: Filename Heading Sync v1.9.1
11: Extract Highlights v0.0.18
12: Frontmatter Links v1.2.7
13: Admonition v10.3.2
14: Dataview v0.5.67
15: Excalidraw v2.7.2
16: Excel to Markdown Table v0.4.0
17: Highlightr v1.2.2
18: Homepage v4.0.7
19: Hotkeys++ v0.2.7
20: Hover Editor v0.11.21
21: Icon Shortcodes v0.9.7
22: Icons v0.3.0
23: Imgur v2.6.3
24: Local REST API v3.0.4
25: Markdown Attributes v1.2.2
26: Mermaid Tools v1.1.3
27: Meta Bind v1.2.5
28: Metadata Menu v0.8.7
29: Natural Language Dates v0.6.2
30: Note Refactor v1.8.2
31: Painter v1.1.0
32: Paste URL into selection v1.7.0
33: QuickAdd v1.11.5
34: Reminder v1.1.17
35: Search Everywhere v1.0.10
36: Snippet Downloader v2.0.1
37: Style Settings v1.0.9
38: Templater v2.9.1
39: Text Snippets v0.1.2
40: Vertical Tabs View v2.6.0
41: Emoji Toolbar v0.4.1
I disable all the plugins and continue the same behavior.
I put it on restricted mode same behavior.
I also used the sandbox and the same behavior
I also noticed the offending characters are not visible after I posted the bug in your site.
let me try put them with back ticks.
<o>
