LaTeX vertical bars are not rendered
I am trying to write matrixes in latex that have vertical bars, such as this:
However, what I end up with is this:
I have tried doing this three ways:
  1. The vmatrix environment
$\begin{vmatrix}a & b & c \\ d & e & f \\ g & h & j\end{vmatrix} = a\begin{vmatrix}e & f \\ h & j\end{vmatrix} - b \begin{vmatrix}d & f  \\ g & j\end{vmatrix} + c \begin{vmatrix}d & e \\ g & h\end{vmatrix}$
  1. The \mdet command in the physics package
$$\require{physics}$$
$\mdet{a & b & c \\ d & e & f \\ g & h & j} = a \mdet{e & f \\ h & j} - b \mdet{d & f  \\ g & j} + c \mdet{d & e \\ g & h}$
  1. The array environment
$\left| \begin{array}a & b & c \\ d & e & f \\ g & h & j\end{array}\right| = \left| a\begin{array}e & f \\ h & j\end{array} \right| - b \left|\begin{array}d & f  \\ g & j\end{array}\right| + c \left|\begin{array}d & e \\ g & h\end{array}\right|$
All three approaches produce the same outcome with no vertical bars. However, the following actions do result in proper rendering:
  1. Disabling hardware acceleration
  2. Setting font size to 10. Does not work for any size larger or smaller
  3. On my android devices, it renders fine.
  4. Any matrix with only one row has proper rendering
However I can’t really work with font size 10 or disable hardware acceleration, so if anyone could help fix this issue that would be great.
