LaTeX \mbox not correctly displayed in Publish
Use mbox in an equation, e.g.:
$\mbox{softmax}(\frac{QK^T}{\sqrt{d_k}})V$
Yes
Rendering like in LaTeX or Obsidian itself:
Screenshot 2024-06-29 at 11.57.16
Rendered in Publish as:
Screenshot 2024-06-29 at 11.58.11
Notice that the letters in softmax are rendered as math symbols (squiggly), whereas they should be rendered as normal text.
(I also tried the amsmath \text command, but it has the same issue.)
Obsidian version: v1.6.5
Installer version: v1.5.12
Operating system: Darwin Kernel Version 23.5.0: Wed May 1 20:12:58 PDT 2024; root:xnu-10063.121.3~5/RELEASE_ARM64_T6000 23.5.0
Catalyst license: insider
which browser are you using?
does it happen in chrome?
does it happen here?
Safari 17.5.0 on macOS 14.5.
It renders correctly in Chrome.
No, on the MathJax demo page it seems to render correctly in Safari:
Screenshot 2024-07-06 at 10.37.57
I was wondering if there are any updates. I used Quartz since my last post to work around the issue, but I would like to switch back to Obsidian Publish because it’s more convenient. But mbox still seems to render badly on Safari (while fine on Chrome-based browsers).
There are not rendered as math symbols. They are not squiggly (cursive).
As a sidenote, from latex pov. you should use \operatorname{softmax}.
Anyway, this is an know bug of safari/mathjax:
Thanks for the pointer!
