While using inline or block math code, use the \biggr, \big, \Biggr, or any of those variations with a vertical line | (or \rvert, \lvert, or \left| and \right|)
The vertical line should render, bigger as indicated by the command.
In live preview mode, and preview mode, the vertical bar does not render if any resizing commands are used prior (the ones listed above)
- Operating system: Windows 11 Pro
- Debug info:
Obsidian version: v0.15.9
Installer version: v0.15.9
Operating system: Windows 10 Pro 10.0.22000
Legacy editor: off
It does render if you generate a PDF from the page. Subscripts or superscripts that are attached to the vertical line do move accordingly in live/preview mode, indicating that the command works, the line is just simply invisible.
Code example: (Happens with both single $ and double $)
$\text{This is an example substitution } \frac{\partial{f}}{\partial{x}} = \big\lvert_{x=1} =$
From Live Preview
From Preview
From Export as PDF
This happens in both light and dark themes.
