LaTeX equations and sections labels with Markdown and Pandoc
We won’t support equation numbering due to different ways in which Mathjax and Obsidian work. I suggest to leave out or comment the \label in the equations.
$$x=y+1 \tag{1} \label{eq1}$$
As shown in $\eqref{eq1}$, $x$ is grether than $y$.
  • An alternative consists in converting Markdown to LaTeX using pandoc-eqnos filters with this syntax:
$$ y = mx + b $$ {#eq:id}
The prefix #eq: is required. id should be replaced with a unique string composed of letters, numbers, dashes and underscores. If id is omitted then the equation will be numbered but unreferenceable.
To reference the equation, use
@eq:id
  • Sections can also be labelled as {#sec:my-section} and refered with @sec:my-section
:arrow_right: These labels are visibles in Edit and View mode. It would be nice if they could be hidden in View mode like in VScode (for sections only, see below).
:arrow_right: #eq:id is not interpreted in Obsidian as a tag, but it would be nice to search for equations across Obsidian.
Current workaround
The labels are visibles both in Edit and View modes:
For sections in VScode the labels are hidden:
Related feature requests
You just need to change the syntax you use for math blocks.
Use
equation
{#eq:equation}
instead of
equation
$$ {#eq:equation}
Then, the equation will be rendered correctly in preview mode and pandoc can still works well.
