Large vault slow to load on with all plugins disabled
@atkirtland
Mod-edit: it’s unnecessary for other user to attempt this procedure below because it was already clarified that this is not a regression introduced in V1.7.
If you believe that this is a regression of 1.7.x and your are willing to do some work you can:
  1. Have a backup
  2. Uninstall obsidian from your phone (your vault will not be deleted)
  3. Manually install version 1.6.7 from here apk
  4. Let me know if it is slow or not.
Bit of a delay because I just saw this now. I tried installing 1.6.7, and I was surprised to find that it also took a long time to load (about 2 minutes). Is there a caching mechanism that gets built slowly over time using the app? This would explain the load time discrepancies between now and when I used 1.6.x prior to a few weeks ago. More explicitly, depending on the amount of time it takes to run, either:
  1. The 1.7.x update never had time to run to completion, and hence all the load times I listed represented sub-optimal times. I’m not sure how long they would take to build, but I have been using 1.7.x versions since probably a few days after they were released.
  2. The 1.7.x version did have time to run to completion, but the time with the fully built cache is slower than with the 1.6.7 version.
If this cache building mechanism exists, is there a way to “bring it to the foreground” and force it to run to completion at once? Continuing to use the 1.6.7 version over a few days will also help me disambiguate these possibilities.
Here are my debug info blocks:
	Operating system: android 14 (samsung SM-S918U1)
	Obsidian version: 1.7.5 (168)
	API version: v1.7.5
	Live preview: off
	Obsidian version: 1.6.7 (149)
	API version: v1.6.6
	Live preview: off
I am glad we ruled out regressions.
The cache building mostly happens after obsidian has started/is in a usable state. You’ll see “Obsidian is indexing your vault” notification and it’ll run when you have obsidian open.
There is some disk activity at lunch, when obsidian checks which files are present.
I can’t reproduce your problem on my Pixel 6a.
Is it possible that your specific phone vendor (Samsung) posted some android update that severely impacted the speed at which obsidian can read from disk?
When you install 1.7.4, can you post a screen recording of you whole loading sequence? thanks.
If any developers happens to have this problem, can you provide us a performance profile of app during startup By reloading the app after it loads through the connected console or using the reload without saving command.
Start Obsidian so I can use it
  1. Files and Links > Rebuild
  2. Disabled individual community plugins
  3. Turned on safe mode
The same vault loads fine on Windoze
Not sure if it happened since the most recent Insider Release
I also downgraded to 1.6.7 and this still happens.
I also downgraded and still it needs minutes to load… - should I maybe factory reset my Phone? … what else could I try?
I don’t think there’s any need to downgrade anymore. I just suggested it because some of you had the doubt that this was a regression introduced by 1.7.x.
Doing a factory reset of your phone is quite traumatic and, if this is caused by a system update, the problem will manifest it’s again.
In these two posts you suppose, that some internal process of the android system is slowing down the file reading process of obsidian.
Do you have any idea how I could investigate that? For example which apps I could deactivate, which settings I could check, which system checks I could do?
In Chrome, I got a log of the console activity during reload, as well as a trace (with Web Developer options I think)- is this what you were looking for? I can DM you a link to download them since I’m not sure if the trace contains information from my vault, and it is fairly large.
yes, thanks. please DM me the link.
Bumping this so it doesn’t get closed for inactivity. I have timing logs with and without plugins on Android, and with on Win 11 here. I have a few ten thousand md files, and many more non-md files. Another possible cause might be obsidian doing more than it should be with files it should skip after seeing only the filenames (like exe or o or dll or similar) (which could also be related to the “should only happen once” message coming up multiple times for some people, and to that process getting stuck for a long time on some of its counted numbers).
Here is my startup time.
@WhiteNoise : would it be possible to list the diffrent startup times of the core plugins, like the community plugins?
Obsidian start-up time breakdown
Operating system: android 14 (samsung SM-G991B)
Obsidian version: 1.7.7 (171)
API version: v1.7.7
  • Total startup time: 927,990ms
  • Initialization: 557ms
  • Vault (42,963 files): 26,426ms
  • Workspace (20 tabs, 19 deferred): 1,085ms
  • Core plugins: 895,962ms
  • Community plugins (24 active): 3,959ms
    • Excalidraw (v2.7.4): 806ms
    • Map View (v5.0.3): 475ms
    • QuickAdd (v1.11.5): 255ms
    • PodNotes (v2.13.3): 241ms
    • Dataview (v0.5.67): 241ms
    • MSG Handler (v0.0.6): 179ms
    • Tasks (v7.14.0): 139ms
    • Spaced Repetition (v1.13.2): 136ms
    • Solve (v1.0.3): 124ms
    • Quick Latex (v2.6.5): 97ms
    • Templater (v2.9.1): 89ms
    • Hotkeys for templates (v1.4.3): 76ms
    • Voice (v1.0.0): 67ms
    • Recent Files (v1.7.3): 62ms
    • Strange New Worlds (v2.3.2): 55ms
    • Style Settings (v1.0.9): 55ms
    • Whisper (v1.5.5): 51ms
    • Commander (v0.5.2): 49ms
    • Periodic Notes (v0.0.17): 45ms
    • Minimal Theme Settings (v8.1.1): 45ms
    • Tag Wrangler (v0.6.1): 38ms
    • Hotkeys++ (v0.2.7): 26ms
    • File path to URI (v1.4.1): 16ms
    • Underline (v1.3.0): 13ms
Thanks, but here we only take slow startup time with restricted mode on.
Hi,
Sorry for that unspecific post. As I went through that whole troubleshooting process before (see my posts above), I only wanted to ask, why the startup time of the core plugins are not listed separately => because the sumed up startup time points to a problem of one of the core plugins…?
Another question:
Is there any chance that a suncthing synchronization between android and windows could provoke that slowed down startup process?
I had the same problem myself recently (there’s a discussion on discord) and the search and files core plugins seemed to be the biggest slowdowns for me. I’ve noticed that anything that lists files is particularly slow on my Android phone. Not sure if it’s a hardware limitation or a software thing, but it happens across the board, not just in Obsidian.
