- Ensure fresh start to avoid any weird contamination (delete .obsidian folder, delete AppData obsidian folder, fresh install, etc.)
- Open an Obsidian vault with ~90k notes.
- Close Obsidian.
Y
Nothing involving Obsidian shows in Task Manager:
Obsidian is able to open as normal on a re-launch.
Obsidian.exe remains in Task Manager:
If you try and re-open Obsidian with that task still there, you get this error:
An error occured while loading Obsidian. UnknownError: Internal error opening backing store for indexedDB.open.
Obsidian version: v1.8.4
Installer version: v1.8.4
Operating system: Windows 11 Home 10.0.26100
Plugins installed: 0
Plugins enabled: 0
Current Workaround(s)
Open Task Manager and close Obsidian between each launch.
What happened immediately before this issue showed up
I havenât added anything recently that could have caused this, just notes in plain English; it just randomly decided to start playing up as I was adding notes and moving links around.
The first clue that something was wrong was that the Omnisearch plug-in stopped working, it just showed as blank when I tried to open it, then after a restart to try and fix it I started getting that error message and had the most confusing time trying to fix things.
Assumptions
I have gone with a fresh installation with no plug-ins and the issue remains, so Iâm not sure if Omnisearch just knew what was up or whether that was somehow related.
Obsidian is able to properly close and be re-opened normally using the test vault, so Iâm assuming the issue is to do with the amount of files in my vault.
Iâm presuming this IndexedDB error shows up when you load Obsidian because IndexedDB is already being read, and so the application is unable to open it twice.
Most likely an OS-independent issue
I actually uninstalled Fedora OS (Linux) and installed Windows 11 on my laptop to try and fix this: same issue, so Iâm assuming this is an OS-independent issue. I imagine the task stayed on Fedora as well, though I wasnât able to check at the time.
Vault information
The exact number of notes is 89,822 notes.
I have two base sub-folders, 10_Meta and 90_Notes:
10_Meta folder (attachments: JPG, PNG, JPEG):
In 10_Templates (Scripts has JS files, Templates has .md files):
All other markdown notes are contained within a single folder (90_Notes):
In the vault I have basic image attachments (JPG, JPEG, PNG), and a bunch of notes that are linked together, though I donât have any fancy files in there or really much in terms of weird characters. The vault is predominately English (some German), though includes generally long file names and some file names contain emoji characters.
