Lag problem caused by tag suggestions - Please Help
Hello,
I experience a terrible lag by the autocomplete after the ‘#’ character. I hardly use tags, but I still need to write headings such as ‘## Header’ .
How can I deactive it? or at least make the suggestion box appear after a few seconds? the lag interferes with the writing flow
Cristian
Hi!
For bug reports, you need to follow and include the bug report template. Thanks.
Hi thanks, I could not find the template, So I changed the message to a ‘call for help’
When you click “New Topic” and choose “Bug reports”, the template is there:
The main things to try first are here:
Hello @ariehen the lag was caused by one of the third party plugins, could you please close this one?
For me, turning the Iconic plugin off then restarting Obsidian removes the lag.
yes, for me that was the culprit. I did not remove Iconic but I turned off ‘Show suggestion icons’
