Lag in VIM mode
Obsidian lags on repeating UP/DOWN/LEFT/RIGHT. Repeating activates when I press and hold mentioned navigation key. Same works well without lag in other editors like VS Code and Notepad++.
VIM enabled, insert mode - no lag
VIM enabled, normal mode - lagging
VIM disabled - no lag
Obsidian installer version - 1.6.7, older installer ver. had same problem too, upgrade to current ver. didnt help.
Windows 10
Bug reports need the bug report template followed and included in the report. Thanks.
Moved to help for now.
Just noticed that after disabling Vimrc extension lag disappears.
In particular, if I disable Vimrc extension setting “Vim Chord Display” AND restart Obsidian, the lag disappears.
Finally, I found that culprit was my own CSS snippet. It had a cumbersome CSS selector. After disabling this CSS snippet and restarting Obsidian everything went smooth again.
